跳转到主内容
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
在 FlexGroup 上运行配额调整大小后出现紧急情况
43
Visibility:
Votes:
0
Category:
not set
Specialty:
not set
Last Updated:
适用于
  • ONTAP 9
问题
如果在活动 FlexGroup 配额策略中添加或删除了默认配额规则、然后volume quota resize在 NFS 文件活动时添加或删除了某个卷、则可能会出现类似于以下内容的页面故障紧急情况:
PANIC: page fault (supervisor read data, page not present) on VA 0x2e0 cs:rip 0x20:0xffffffff8df5ed25 rflags 0x10202 in SK process wafl_exempt06
New to NetApp?
Scan to view the article on your device
  • 这篇文章对您有帮助吗?
