跳转到主内容
无法连接到Vscan服务器
32
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
适用场景
  • ONTAP 9
  • Vscan
问题描述
  • 即使已启用Vscan且ONTAP防病毒 连接器连接测试成功、防病毒扫描程序也不会连接:
::> vserver vscan connection-status show-all
Connection
Vserver Node Server Status Disconnect Reason
SVM01 Cluster01-n1 10.10.10.11 disconnected -
SVM01 Cluster01-n1 10.10.10.12 disconnected -
2 entries were displayed.
  •  AV Connector日志:
04/14/21 ------------------------------------------------------------------------------------------
04/14/21 ONTAP AV Connector started at 17:07:22 Mo, Apr 14, 2021 (Local time)
04/14/21 Version: 1.0.5
04/14/21 Log On As: Demo\AVConn
04/14/21 Service Pid : 1420
04/14/21 Log's timestamps are GMT and format is mm/dd/yy-hh:mm:ss.mmm
04/14/21 Added data LIF data_lif01
04/14/21 Error 87 processing entry data-lif::data_lif01 from config SOFTWARE\Data Ontap\Clustered Data ONTAP Antivirus Connector\v1.0\data-lifs
04/14/21 87 processing SOFTWARE\Data Ontap\Clustered Data ONTAP Antivirus Connector\v1.0\data-lifs
04/14/21 Error 87 loading data config
04/14/21 [LifParam::ReconcileLifThreads] [plp: data_lif01, ] in_use: [1]
04/14/21 [LifParam::ReconcileLifThreads] [plp: SVM01-vscan, ] in_use: [1]
04/14/21 [Pipe: -> ][r] Waiting for scanner to register before opening the pipe
  • EMS:
Nblade.vscanNoScannerConn:EMERGENCY]: Vserver "SVM_1" has no virus scanner connection.
New to NetApp?
