由于数据源错误, ONTAP 卷移动中止
适用场景
ONTAP 9
问题描述
- 卷移动失败,并显示以下错误:
cluster::> volume move show -vserver svm1 -volume vol1 Vserver Name: svm1 Volume Name: vol1 Actual Completion Time: Fri Oct 08 05:57:25 2021 Bytes Remaining: - Destination Aggregate: aggr2 Detailed Status: Aborting Volume Move. Data Source Error.. Sender data source error. Estimated Time of Completion: - Managing Node: cluster-01 Percentage Complete: - Move Phase: failed Estimated Remaining Duration: - Replication Throughput: 100.0MB/s Duration of Move: 14:06:54 Source Aggregate: aggr1 Start Time of Move: Thu Oct 07 15:50:31 2021 Move State: failed Is Source Volume Encrypted: false Encryption Key ID of Source Volume: Is Destination Volume Encrypted: false Encryption Key ID of Destination Volume:
- 在 EMS 日志中可以看到以下消息
Fri Oct 08 05:57:23 -0700 [cluster-01: repl_non_block: wafl.repl.src.inconsistent:error]: volume: vol1@vserver:22cf0566-ef65-11e4-a8b2-123478563412: WAFL metadata inconsistent due to disk errors. (vvbn:1105766759 level:0 file_type:15). Aborting transfer.
Fri Oct 08 05:57:25 -0700 [cluster-01: mgwd: mgmtgwd.jobmgr.jobcomplete.failure:info]: Job "Volume Move" [id 345714] (Move "vol1" in Vserver "svm1" to aggregate "aggr1") completed unsuccessfully: Aborting Volume Move. Data Source Error.. Sender data source error. (1).
- 这可能会使卷发生原因 to Go WAFL 不一致。
