跳转到主内容
由于 BCOmd , ONTAP 从 8.3 升级到 9.1 的操作已中止 脱机
20
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
适用于
ONTAP 从 8.3 升级到 9.1
问题
由于 BCOMD" 脱机 " , ONTAP 从 8.3 升级到 9.1 的操作已中止。
错误示例:
::*> system node upgrade-revert show
Node: node01                     Status: aborted
Status Message: The upgrade aborted. Contact support personnel for the upgrade repair procedure.
Vers Phase    Status   Upgrade Phase Status Message
420  pre-root   applied  No upgrade is required for this phase.
420  pre-apps   applied  Upgrade successful.
420  post-apps  applied  Upgrade successful.
510  pre-root   applied  No upgrade is required for this phase.
510  pre-apps   applied  Upgrade successful.
510  post-apps  aborted  Node "node01" on ring "Bcom" is offline.
Node      Vers Phase    ID  Proc   Status    Description
node01    500 post-apps 504 mgwd   applied   FlexCache UpgradeRevert App Task For 9.0
node01    500 post-apps 505 mgwd   applied   Predefined_roles_update_upgrade
node01    500 post-apps 506 mgwd   applied   Predefined_roles_update_revert
node01    500 post-apps 508 mgwd   applied   Upgrade_Revert of 9.0.0 FPolicy Features
node01    500 post-apps 510 mgwd   applied   Session Limits Upgrade/Revert Task
node01    500 post-apps 514 mgwd   applied   Web Services 9.0.0 RDB Upgrade/Revert Task
node01    500 post-apps 515 mgwd   applied   Web Services 9.0.0 Upgrade/Revert Task
node01    500 post-apps 516 mgwd   applied   Revert Audit records
node01    500 post-apps 519 mgwd   applied   Autobalancer_support
node01    500 post-apps 520 mgwd   applied   InfiniteVol Revert Task
node01    500 post-apps 521 mgwd   applied   InfiniteVol Upgrade Task
node01    500 post-apps 522 mgwd   applied   Upgarde and Revert task for LDAP
node01   500 post-apps 523 bcomd aborted   LUN Map LGID Upgrade/Revert
New to NetApp?
