跳转到主内容
由于邮件主机上的中继问题,未从 Data ONTAP 7- 模式接收 AutoSupport 电子邮件
37
Visibility:
Votes:
0
Category:
data-ontap-8
Specialty:
core
Last Updated:
适用于
  • 集群模式 Data ONTAP
  • Data ONTAP 7-模式
  • SMTP
  • AutoSupport
问题
NetApp 控制器无法将 AutoSupport 电子邮件中继到外部电子邮件地址,包括使用 SMTP 邮件主机服务器的 autosupport@ netapp.com
类似错误消息:
  • message: 550 5.7.1 Unable to relay
  • READMSG:554 Mail from user@domain.com rejected for policy reasons
  • message: Access denied: 550
检查 Autosupopt 历史记录
  • >autosupport history show
       Seq                   Attempt  Percent  Last
Node      Num   Destination Status         Count   Complete Update
node01    1680   smtp     transmission-failed  15     -     5/28/2020 02:20:53
  • 使用“autosupport history show -seq-num ### -instance”命令查看特定顺序和Last ErrorFailed sending data to the peer。
Node> system autosupport history show -seq-num 1680 -instance
               Node: node01
   AutoSupport Sequence Number: 1680
Destination for This AutoSupport: smtp
          Trigger Event: callhome.management.log
       Time of Last Update: 5/28/2020 02:20:53
        Status of Delivery: transmission-failed
        Delivery Attempts: 15
       AutoSupport Subject: MANAGEMENT_LOG
           Delivery URI: mailto:autosupport@netapp.com
            Last Error: Failed sending data to the peer
        Time of Generation: 5/28/2020 00:01:51
   AutoSupport Compressed Size: 131.4KB
         Percent Complete: -
          Rate of Upload: -
    Time Remaining for Upload: 0s
  AutoSupport Decompressed Size: 476.0KB
    Total Collection Time (ms): 6257
可以通过 notifyd.log查看/mroot/etc/log/mlog/notifyd.log 或查看您组织的邮件主机日志来查看 AutoSupport 子系统中记录的错误来确定详细的错误消息。
如何查看 notifyd . log
>rdfile /etc/log/mlog/notifyd.log
输出示例:
(emittime: 8/6/2017 01:16:27) (message: RCPT TO:<autosupport@netapp.com>)
(emittime: 8/6/2017 01:16:27) (message: SMTP 0x8115ae810 state change from MAIL to RCPT)
(emittime: 8/6/2017 01:16:32) (message: 550 5.7.1 Unable to relay)
(emittime: 7/7/2017 05:10:31) (message: DO phase starts)
(emittime: 7/7/2017 05:10:31) (message: MAIL FROM:<user@domain.com>)
(emittime: 7/7/2017 05:10:31) (message: SMTP 0x812b31810 state change from STOP to MAIL)
(emittime: 7/7/2017 05:10:31) (message: 554 Mail from user@domain.com rejected for policy reasons.)
(emittime: 3/11/2015 10:11:58) (message: Access denied: 550)
New to NetApp?
