跳转到主内容
在ONTAP 9.8或更高版本中、卷级别和聚合级别不会通过数据压缩(报告0)节省空间
223
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9.8或更高版本
  • 温度敏感型存储效率(T(SSE))
问题描述
  • 在ONTAP 9.8中、启用了自动自适应实时数据压缩的所有卷都会显示0B 数据压缩:
::*> aggr show-efficiency -aggregate !*root,!*snaplock -fields volume-compression-saved
aggregate              volume-compression-saved
aggr1              0B
aggr2                  0B
  • 卷显示重复数据删除节省的空间、但数据压缩未节省任何空间:
::*> volume show -volume vol* -fields dedupe-space-saved,dedupe-space-saved-percent,compression-space-saved,compression-space-saved-percent vserver volume dedupe-space-saved dedupe-space-saved-percent compression-space-saved compression-space-saved-percent -------- -------------------- ------------------ -------------------------- ----------------------- ------------------------------- svm1 vol3 111.6GB 7% 0B 0% svm1 vol4 184.2GB 10% 0B 0%
  • 尝试手动运行数据压缩失败、并显示错误:
::*> volume efficiency start -vserver svm1 -volume vol1 -dedupe true -compression true -compaction true -scan-old-data true Warning: This operation scans all of the data in volume "vol1" of Vserver "svm1". It might take a significant time, and degrade performance during that time. Do you want to continue? {y|n}: y Error: command failed: Failed to start efficiency on volume "vol1" of Vserver "svm1": "-compression" option is not supported on auto-adaptive compression enabled volumes.
New to NetApp?
