跳转到主内容
使用 HTTPS 时 ONTAP AutoSupport 消息失败: SSL 证书问题
102
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
适用场景
  • ONTAP 9
  •  用于AutoSupport消息的HTTPS传输协议
问题描述
  • 使用HTTPS作为传输的AutoSupport消息失败:
::> system node autosupport history show -node node_name -seq-num <seq_num> -instance
                 Node: node_name
     AutoSupport Sequence Number: seq_num
   Destination for This AutoSupport: https
            Trigger Event: callhome.management.log
         Time of Last Update: 1/12/2021 02:58:59
          Status of Delivery: transmission-failed
          Delivery Attempts: 15
         AutoSupport Subject: MANAGEMENT_LOG
             Delivery URI: 10.106.130.129:8080(support.netapp.com/put/AsupPut)
              Last Error: SSL certificate problem: unable to get local issuer certificate
::> autosupport check show-details -node node_name
      Node: node_name
    Category: http-https
   Component: http-put-destination
     Status: failed
     Detail: HTTP/S PUT connectivity check failed for destination:
           https://support.netapp.com/put/AsupPut/ via proxy -
           123.123.123.123:8080. Error: Peer certificate can not be
           authenticated with given Certificate Authority
           certificates.
 Corrective Action: Certificate issue. Please make sure you have the correct
           Root Certificate installed
   Component: http-post-destination
     Status: failed
     Detail: HTTP/S POST connectivity check failed for destination:
           https://support.netapp.com/asupprod/post/1.0/postAsup
           via proxy - 123.123.123.123:8080. Error: Peer certificate
           can not be authenticated with given Certificate
           Authority certificates.
  • 使用HTTP作为传输协议、AutoSupport消息可以成功传送到NetApp。
  • 类似的错误消息:
message: SSL certificate problem: self signed certificate in certificate chain
Error: Peer certificate 无法使用给定进行身份验证 Certificate Authority certificates.
Error: asup.post.drop: AutoSupport message (HA Group Notification from node01 (USER_TRIGGERED (TEST:Test)) NOTICE) was not posted to NetApp. The system will drop the message.
  • 在中找到其他错误消息  /mroot/etc/log/mlog/notifyd.log:
::> system node run -node <node_name> -command rdfile /etc/log/mlog/notifyd.log
New to NetApp?
