更换主板后的许可证授权风险
适用于
- AFF 系统
- FAS 系统
- ONTAP 9
- 集群模式 Data ONTAP 8.2 及更高版本
问题
控制器报告的许可证授权风险
"Acquire a node-locked license"
指向正常运行的节点。示例
从日志中,我们可以看到节点netapp-cluster-01
已被更换,但系统报告节点的许可证缺失 netapp-cluster-02.
netapp-cluster::> system license show-status Status License Scope Detailed Status --------- ------------------- --------- ---------------------- partially-installed NFS node License missing on: netapp-cluster-02. CIFS node License missing on: netapp-cluster-02. iSCSI node License missing on: netapp-cluster-02. FCP node License missing on: netapp-cluster-02. SnapRestore node License missing on: netapp-cluster-02. SnapMirror node License missing on: netapp-cluster-02. FlexClone node License missing on: netapp-cluster-02. SnapVault node License missing on: netapp-cluster-02. SnapManagerSuite node License missing on: netapp-cluster-02.
netapp-cluster::> system license entitlement-risk show Package Entitlement Risk Corrective Action ------------------- ---------------- ----------------------------------- NFS unlicensed None Nodes Without a Node-Locked License ------------------------------------------------------------- netapp-cluster-02 1-81-0000000000000004073806283
