跳转到主内容
之后,在其主 ifgrp 的基础端口上发现 LIF ONTAP 9 中的非正常关闭
41
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas<a>ONTAP 9</a><a>LIF</a><a>连接</a><a>LACP</a><a>ifgrp</a><a>0x8089b2800</a>
Last Updated:
适用场景
ONTAP 9
问题描述
  • 在非正常关闭(例如断电)并进行后续恢复后、如果LIF之前驻留在单端口ifgrp上、则可能会在其ifgrp的基本端口上找到它。
    • 在这种情况下、您可能会发现EMS错误、例如:
[vifmgr_virtual_interface_iterator::move_imp] Well-known error thrown while moving LIF LIF_NAME (1000): Failed to update LIF "LIF_NAME" because port "CLUSTER-01:a0a" is in a different broadcast domain than the LIF's home port. Use the "network port broadcast-domain show" command to identify a port in the same broadcast domain as port "CLUSTER-01:e0c"
[kern_vifmgr:info:5526] [0x8089b2800] [FailoverMgr::scanIncorrigibleVifs] LIF LIF_NAME (1000) has no available failover targets on this node.
  • 运行时 network interface show -lif LIF_NAME -instance,您可能会看到以下状态:
Operational Status: down
Extended Status: This LIF is down because all failover targets are either down or otherwise unavailable. Use the "network interface show -failover" command to review the LIF's failover configuration.
  • 在这种情况下、您可能也无法从LIF执行ping操作、这表示没有来自该接口的网络连接。
New to NetApp?
