跳转到主内容
LDAPS或LDAP+StartTLS连接因缺少CA证书而失败
130
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
适用场景
  • ONTAP
  • LDAP服务器
  • Active Directory
  • SSL/TLS协议
问题描述
  • EMS:
secd.ldap.noServers: None of the LDAP servers configured for Vserver (VS1) are currently accessible via the network for LDAP service type (Service: LDAP (Active Directory), Operation: SiteDiscovery).
secd.ldap.noServers: None of the LDAP servers configured for Vserver (VS1) are currently accessible via the network for LDAP service type (Service: LDAP (Active Directory), Operation: MapNetbiosDomainToADDomain).
  • SECD:
[    74] Successfully connected to ip x.x.x.x, port 389 using TCP
[    87] Required certificate with CA ClientAccessRootCA is not installed
[    87] Unable to start TLS: Connect error
[    87]   Additional info: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed (unable to get local issuer certificate)
Transport Layer Security
    TLSv1.2 Record Layer: Handshake Protocol: Multiple Handshake Messages
        Content Type: Handshake (22)
        Version: TLS 1.2 (0x0303)
        Length: 2911
        Handshake Protocol: Server Hello
        Handshake Protocol: Certificate
            Handshake Type: Certificate (11)
            Length: 2587
            Certificates Length: 2584
            Certificates (2584 bytes)
                Certificate Length: 1208
                Certificate: 308204b43082039ca0030201020213160000802cf3c5747b… (id-at-commonName=LDAPserverhostname)
                    signedCertificate
                        version: v3 (2)
                        serialNumber: 0x160000802cf3c5747b5475eb2100000000802c
                        signature (sha256WithRSAEncryption)
                       issuer: rdnSequence (0)
                            rdnSequence: 3 items (id-at-commonName=Issuer CA )
                        validity
                        subject: rdnSequence (0)
                        subjectPublicKeyInfo
                        extensions: 9 items
                    algorithmIdentifier (sha256WithRSAEncryption)
                    Padding: 0
                    encrypted: d403151937a2904d0405e5fe7be043a51969650e43cc27e0…
                Certificate Length: 1370
               Certificate: 308205563082033ea00302010211114500000002578509d7… (id-at-commonName=Issuer CA )
                    signedCertificate
                        version: v3 (2)
                        serialNumber: 0x4500000002578509d77c523cae000000000002
                            rdnSequence: 3 items (id-at-commonName=Root CA)
New to NetApp?
  • 这篇文章对您有帮助吗?
