跳转到主内容
如何解决 VMware ESXi 上的 NFS APD 问题
410
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
适用于
  • ONTAP 9
  • VMware ESXi
  • NFS
描述
  • 当任何给定的 TCP 流上有 5 秒时间段没有通信时,将启动所有路径关闭(APD)计时器
  • 处于此状态 140 秒后,连接将被视为丢失并达到 APD 超时
    • VMware 日志中可能出现的错误包括但不限于:
YYYY-MM-DD T00:26:51.504Z: [APDCorrelator] xxxxxxxxxxxxxus: [esx.problem.storage.apd.timeout] Device or filesystem with identifier [xxxxxxxx-xxxxxxxx] has entered the All Paths Down Timeout state after being in the All Paths Down state for 140 seconds. I/Os will now be fast failed.
NFSLock: 608: Stop accessing fd 0x410011446d28  3
NFS: 133: Lost connection to the server 192.168.0.1 mount point /vol/datastore, mounted as xxxxxxxxx-xxxxxxxx-0000-000000000000 (“datastore”)
StorageApdHandler: 248: APD Timer started for ident [xxxxxxxx-xxxxxxxx]
StorageApdHandler: 846: APD Start for ident [xxxxxxxx-xxxxxxxx]!
StorageApdHandler: 277: APD Timer killed for ident [xxxxxxxx-xxxxxxxx]
StorageApdHandler: 902: APD Exit
[vob.storage.apd.start] Device or filesystem with identifier [xxxxxx-xxxxxxx] has entered the All Paths Down state
WARNING: NFS: xxx: Lost connection to the server xxxx mount point /xxxx, mounted as xxxxxx-xxxxxx-0000-000000000000 ("xxxxxxxx")
  • ONTAP 可能在 APD 时记录
kernel: Nblade.nfsConnResetAndClose:error]: Shutting down connection with the client. Vserver ID is xx; network data protocol is NFS, Rpc Xid xxxxx; client IP address:port is x.x.x.x:xxxx. local IP address is x.x.x.x; reason is CSM error - Maximum number of rewind attempts has been exceeded
ERROR Nblade.CallbackTimedOut: SM NOTIFY: Vserver xx, Vif xxx: PORTMAP program (Program number:100000 Program version:2) on client x.x.x.x is not responding
New to NetApp?
