跳转到主内容
如何将具有255个以上快照的FlexVol 转换为FlexGroup
95
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9
  • FlexGroup
问题描述
  • ONTAP 9.7允许将FlexVol 转换为FlexGroup
  • 但是、在ONTAP 9.7中
    • FlexGroup 只能支持少于255个快照
    • FlexVol最多可支持1023个快照。
如果在所有版本的ONTAP 9.7中转换具有255个以上快照的FlexVol 、则会引发以下错误:
cluster01::> version
NetApp Release 9.7P1: Thu Feb 27 01:25:24 UTC 2020
cluster01::>
cluster01::*> volume conversion start -volume myvol -foreground true -check-only true
Error: command failed: Cannot convert volume "myvol" in Vserver "svm1" to a
       FlexGroup. Correct the following issues and retry the command:
       * The volume has more than 254 snapshot copies.  Use the "volume
       snapshot show -vserver svm1 -volume myvol" command to list the Snapshot
       copies present on the volume and remove one or more of them with the
      "snapshot delete -vserver svm1 -volume myvol" command.
       * The volume has Snapshot copies with IDs greater than 255.  Use the
       (privilege: advanced) "volume snapshot show -vserver svm1 -volume myvol
       -logical-snap-id >255 -fields logical-snap-id" command to list the
       Snapshot copies with IDs greater than 255 then delete them using the
New to NetApp?
