如何从 Solaris 主机检查 HBA 和链接速度?
不可不使用
适用场景
- Solaris 操作系统
- SAN 协议
问题解答
- 使用
sanlun fcp show adapter -v <adapter>
用于显示有关 HBA 的信息的命令:
# sanlun fcp show adapter -v lpfc1 lpfc1 WWPN:10000000fedcba98 WWNN: 20000000fedcba98 driver name: lpfc model: LP9002 model description: Emulex LightPulse LP9002 2 Gigabit PCI Fibre Channel Adapter serial number: 0000c92bfe6a hardware version: 2002606d driver version: 5.00e; HBAAPI v1.3, 3-29-02 firmware version: 3.90A7 (C2D3.90A7) Number of ports: 1 port type: Fabric port state: Operational supported speed: 2 GBit/sec negotiated speed: 2 GBit/sec OS device name: /devices/pci@8,700000/fibre-channel@3
- 对于未安装 Solaris 主机实用程序套件的主机、可以使用以下命令找到类似信息:
fcinfo hba-port -l
command:
BA Port WWN: 10000000fedcba98 OS Device Name: /dev/cfg/c3 Manufacturer: Emulex Model: LPe12002-S Firmware Version: 1.00a12 (U3D1.00A12) FCode/BIOS Version: Boot:5.03a0 Fcode:3.01a1 Serial Number: 4925382+12450000M8 Driver Name: emlxs Driver Version: 2.90.15.0 (2014.01.22.14.50) Type: N-port State: online Supported Speeds: 2Gb 4Gb 8Gb Current Speed: 4Gb Node WWN: 20000000fedcba98 Link Error Statistics: Link Failure Count: 1 Loss of Sync Count: 144 Loss of Signal Count: 0 Primitive Seq Protocol Error Count: 0 Invalid Tx Word Count: 7770 Invalid CRC Count: 0
追加信息
不适用
