跳转到主内容
FlexVol 转换到 FlexGroup 会报告 " 访问 " ,但 FlexVol 未转换
37
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用于
ONTAP 9
FlexGroup 转换
问题
通过命令行界面报告将 FlexVol 转换为 FlexGroup success,但实际上并未转换 FlexVol 。
示例:
启动 FlexVol 转换并报告success
cluster01::> set -privilege advanced
cluster::*> vol conversion start -volume test -vserver test
Warning: After the volume is converted to a FlexGroup, it will not be possible to change it back to a flexible volume.
Do you want to continue? {y|n}: y
[Job 7891] Job succeeded: success
Job history 确认 FlexVol 转换为successful
cluster01::*> job history show -id 7891
Time Node Owning Vserver Name Event Job ID
Date Time node vserver
Volume Convert Succeeded 7891
Description: Converting flexible volume to FlexGroup
Completion: success
Volume show 仍然将卷标识为 FlexVol (而不是 FlexGroup ):
cluster::*> volume show -vserver test -volume-style-extended flexgroup
There are no entries matching your query.
New to NetApp?
