跳转到主内容
FabricPool在节点重新启动或网络维护后不可用
50
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>2008554944</a>
Last Updated:
适用场景
  • ONTAP 9
  • FabricPool
问题描述
  • 由于ONTAP升级等维护、节点会重新启动
  • 对象存储将被标记为不可用、冷分层数据不可访问、暖性能层数据访问正常
  • EMS日志中记录的错误会指出、在进行恢复后、对象存储在启动时不可用
Sat Nov 21 14:41:56 -0600 [cluster1: OscLowPriThreadPool: object.store.unavailable:EMERGENCY]: ERROR: BUG in matching parameters (reason) to definition params: {'node_uuid': '9a842a8a-fbfa-11ea-a5c4-00a0987f363a', 'configname': 'stl_fabricpool'}
  • 在节点重新启动之前、系统会记录错误、指出TLS与对象存储的连接失败、并且这些连接正在进行中
Sat Nov 21 12:05:01 CST [cluster1: mgwd: ktls.failed:notice]: "The TLS connections have failed several times with remote host '162.132.35.10' in IPspace '1', for which the latest reason given is: Errno: Connection reset by peer."
Sat Nov 21 12:15:16 CST [cluster1: mgwd: ktls.failed:notice]: "The TLS connections have failed several times with remote host '162.132.35.10' in IPspace '1', for which the latest reason given is: TLS: Handshake timed out."
  • 已根据最佳实践启用TLS
New to NetApp?
