跳转到主内容
NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp KCS Award
节点重新启动后, FabricPool 不可用
6
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用于
  • ONTAP 9
  • FabricPool
问题
  • 由于 ONTAP 等维护,节点将重新启动 升级
  • 对象存储被记录为不可用,冷分层数据无法访问,温性能层数据访问正常运行
  • 在 EMS 日志状态中记录的错误对象存储将变为 交还后启动时不可用
Sat Nov 21 14:41:56 -0600 [cluster1: OscLowPriThreadPool: object.store.unavailable:EMERGENCY]: ERROR: BUG in matching parameters (reason) to definition params: {'node_uuid': '9a842a8a-fbfa-11ea-a5c4-00a0987f363a', 'configname': 'stl_fabricpool'}
  • 在节点重新启动之前,系统会记录错误,指出 TLS 连接无法连接到对象存储,并且这些连接正在进行中
Sat Nov 21 12:05:01 CST [cluster1: mgwd: ktls.failed:notice]: "The TLS connections have failed several times with remote host '162.132.35.10' in IPspace '1', for which the latest reason given is: Errno: Connection reset by peer."
Sat Nov 21 12:15:16 CST [cluster1: mgwd: ktls.failed:notice]: "The TLS connections have failed several times with remote host '162.132.35.10' in IPspace '1', for which the latest reason given is: TLS: Handshake timed out."
  • 根据最佳实践启用 TLS
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
