跳转到主内容
以太网 RLM 和 E0M 接口持续关闭
23
Visibility:
Votes:
0
Category:
data-ontap-7
Specialty:
network
Last Updated:
状态信息
适用于
Data ONTAP 7 及更早版本
问题
以太网 RLM/E0M 接口一直处于关闭状态。有两个 MAC 地址来自同一个 RLM 和 E0M 端口。从安全的角度来看, IOS 会发现 MAC 地址冲突,从而迫使接口关闭。
Fri Dec 11 20:27:07 GMT [3140M: netif.linkUp:info]: Ethernet RLM/e0M: Link up.
Fri Dec 11 20:27:10 GMT [3140M: netif.linkDown:info]: Ethernet RLM/e0M: Link down, check cable.
Fri Dec 11 20:27:53 GMT [3140M: rlm.driver.mailhost:warning]: RLM setup could not access the mailhost specified in 'options autosupport.mailhost'.
Fri Dec 11 20:27:54 GMT [3140M: rlm.driver.network.failure:warning]: The network configuration of the Remote LAN Module (RLM) failed due to cable or network errors.
Fri Dec 11 20:28:00 GMT [3140M: rlm.driver.timeout:warning]: The software driver for the Remote LAN Module (RLM) detected a problem: Cannot send takeover configuration..
Fri Dec 11 20:28:00 GMT [3140M: cf.hwassist.notifyCfgFailed:CRITICAL]: Failed to notify hardware-assist configuration to hardware module (RLM): UNKNOWN(7)
> rlm status
  Remote LAN Module           Status: Online
    Part Number:        110-00057
    Revision:           D0
    Serial Number:      451541
    Firmware Version:   4.0
    Mgmt MAC Address:   00:A0:98:0B:E8:3D
   Ethernet Link:      up, 100Mb, full duplex, auto-neg complete
    Using DHCP:         no
  IPv4 configuration:
    IP Address:         unknown
    Netmask:            unknown
    Gateway:            unknown
  IPv6 configuration:         Disabled
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
