EMS报告spm.mgwd.process.exit:EMERGENCY"
适用场景
- ONTAP 9
- Cloud Volumes ONTAP ( CVO )
问题描述
- EMS报告
spm.mgwd.process.exit:EMERGENCY:
EMERGENCY spm.mgwd.process.exit: Management Gateway (mgwd) subsystem with ID 4150 exited as a result of signal signal 6. The subsystem will attempt to restart.
- ONTAP 系统进程可能发生崩溃、并显示类似以下内容的消息:
ERROR ucore.panicString: 'mgwd: terminating with uncaught exception of type std::bad_alloc: std::bad_alloc, raising SIGABRT(6) at RIP 0x81d87f2fa (pid 4150, uid 0, timestamp 1653066223)'
