在事件日志中以 Cisco 发现协议的形式显示 "CSM 。 mismatchRemoteDevice" 消息 未在存储系统上启用
适用场景
- 集群模式 Data ONTAP
- ONTAP
问题描述
EMS标识符
Cluster01::> event log show -node Clsuter01-01 -event csm*
或
Cluster01::> event log show -node * -event csm*
Time Node Severity Event
1/3/2013 15:08:30 Cluster01-01 WARNING csm.mismatchRemoteDevice: CSM connection between source LIF 1023 and destination address 169.254.237.128 might not be optimal for session 0104d263bc58cd05. The source is currently connected to clus_sw_02 remote device and the destination is currently connected to - remote device.
- 如果 未 启用Cisco发现协议(CDP)、则在EMS消息中、源或目标远程设备将显示为
- 在消息中、目标LIF已连接到
远程设备 - 这表示未读取远程设备
