从 3.4.4.4 降级 BES-53248 固件失败
适用于
- BES — 53248
- 固件降级
- 固件版本 3.4.4.4
问题
从 3.4.4.4 降级 BES-53248 固件失败并显示错误:
bes-switch) #copy <file_path_url> active
Mode........................................... HTTP
Set Server IP.................................. <server_ip>
Path........................................... ./
Filename....................................... EFOS-<destination_version>.stk
Data Type...................................... Code
Destination Filename........................... active
Management access will be blocked for the duration of the transfer
Are you sure you want to start? (y/n) y
File transfer in progress. Management access will be blocked for the duration of the transfer. Please wait...
HTTP Code transfer starting...
File transfer operation failed.
