由于卷配置数据库读取失败(条目不存在),将卷转换为 FlexGroup 失败
适用场景
- ONTAP 9.x
- FlexGroup
问题描述
将卷转换为 FlexGroup 期间,报告错误:
::>volume conversion start -volume TEST -check-only true
Error: command failed: Cannot convert volume "TEST" in Vserver "NetApp" to a FlexGroup because one or more errors occured checking the volume. Reasons:
* Conversion failed with reason Volume config database read failed (entry doesn't exist).
在vol converson validation show
中显示volume-snapmirror-dstconvert-check
错误:
::*>volume conversion validation show -volume TEST -vserver NetApp
Vserver : NetApp
Volume : TEST
Precheck Status
volume-snapmirror-nosnap supported
volume-snapmirror-bre supported
volume-snapmirror-storage-efficiency supported
volume-snapmirror-fvSource supported
volume-snapmirror-LTR supported
volume-snapmirror-VserverDR supported
volume-snapmirror supported
volume-snapmirror-broken supported
volume-snapmirror-fanout supported
volume-snapmirror-dstconvert-check error
Reason : Conversion failed with reason Volume config database read failed
volume-reallocation-schedule supported
volume-nvme-namespace supported
volume-statistics supported
volume-space-slo supported
volume-snapmirror-sync supported
application-volume supported
volume-v4-inode supported
