跳转到主内容
无法使ONTAP中的FlexGroup卷脱机或联机
27
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>2009-141969.</a>
Last Updated:
适用场景
  • ONTAP 9
  • FlexGroup
问题描述
即使使用 -force,FlexGroup卷也不能设置为脱机或联机:
Cluster01::> volume offline -vserver svm1 -volume fg1 -force true
Warning: Forcing offline volume fg1 in Vserver svm1 can potentially disrupt access to files in other volumes.
Do you want to continue? {y|n}: y
[Job 80266] Steps completed: 16 of 17.vol offline: Error offlining volume "svm1:fg1". [Job 80266] Job failed: Failed to change the state of FlexGroup "fg1". The following constituents failed to be modified to the desired state: 2,6,10,14.The error was the same for all constituents, and was "Unable to set volume attributes for volume "fg__0014" on Vserver "svm1". Reason: Volume busy. ".
New to NetApp?
  • 这篇文章对您有帮助吗?
