跳转到主内容
无法在由FAS 和AFF 系统组成的混合集群中使用分区创建聚合
40
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>ADP</a><a>ADPv2</a><a>2008457190</a><a>ADPv1</a>
Last Updated:
适用场景
  • ONTAP 9.7P1及更高版本
  • ONTAP 9.6P6及更高版本
  • ONTAP 9.5P11及更高版本
  • AFF 和FAS 系统的混合集群
  • 一个集群中的四个或更多节点
  • 高级磁盘分区( ADP )
问题描述
在采用混合分区方法的集群中创建聚合失败:
Cluster01::> storage aggregate create -aggregate aggr3 -simulate true -disklist 5.0.1,5.0.3,5.0.5,5.0.7,5.0.9,5.50.1,5.50.3,5.50.5,5.50.7,5.50.9,5.50.11,5.51.1,5.51.3,5.51.5,5.51.7,5.51.9,5.51.11 -node cluster01-03
Error: command failed: Disk "5.0.1" is partitioned with the "root-data" method, which is not supported on this system since this system is initialized with "root-data1-data2". Contact technical support for assistance
注意: 问题描述 也可能相反。  例如:
Error: command failed: Disk "5.0.1" is partitioned with the "root-data1-data2" method, which is not supported on this system since this system is initialized with "root-data". Contact technical support for assistance
New to NetApp?
