跳转到主内容
更改卷配额大小后,无法在此卷上设置配额
34
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用于
ONTAP 9
问题
  • 更改卷配额大小后,无法在此卷上设置配额。
示例:
Cluster::> quota on -vserver svm -volume volname
Cluster::> quota status -vserver svm -volume volname
        Vserver Name: svm
        Volume Name: volname
        Quota State: Quotas are initializing and transferring rules
        Vserver Name: svm
        Quota State: Quotas are off
  • 通过 EMS 日志,可以看到在未找到用户名后配额操作失败以及 Unix 用户查找失败。
示例
[nodename mgwd: mgmtgwd.jobmgr.jobcomplete.failure:info]: Job "Quota Operation" [id 10254] ("quota on" performed for quota policy "default" on volume "volname" in Vserver "svm") completed unsuccessfully: User name user1 not found. Reason: SecD Error: libc returned a transient error. Please look at the journal for detail. (1258185)
[nodename : secd: secd.unixLookupFailure:error]: vserver (svm) UNIX lookup failure. Error: Acquire UNIX credentials procedure failed
  [  1 ms] Successfully connected to ip 10.163.50.15, port 756 using TCP
  [    1] Unable to connect to NIS service on 10.163.50.15 (Error: Could not connect to server)
  [    1] No servers available for NIS, vserver: 11, domain: .
**[    1] FAILURE: Unable to make a connection (NIS:), result: 6940
  [    1] Source: NIS unavailable. Ignoring and trying next available source for user-name: user1
  [    2] Entry for user-name: chenj not found in the current source: FILES. Entry for user-name: user1 not found in any of the available sources
  [    2] Unable to retrieve UID for UNIX user user1
  • 通过 MGWD 日志,可以查看进度详细的故障进度。
示例
[kern_mgwd:info:1684] 0x83725b600: 8603e900000133b0: ERR: VOPL::QuotaOps: JOB[10257]: pushRules: Cancel quota op after failure(User name user1 not found. Reason: SecD Error: libc returned a transient error. Please look at the journal for detail. ) from copy rules to zapi; retry count is 8
New to NetApp?
  • 这篇文章对您有帮助吗?
