跳转到主内容
CSHM : ClusterSwitchConfig_Alert :由于集群交换机布线错误,系统运行状况已降级
21
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • 集群模式 Data ONTAP 8
  • 集群交换机运行状况监控器( CSHM ) AutoSupport 消息
问题描述
  1. 系统运行状况已降级
cluster::>system health status show
Status
degraded
  1. 交换机运行状况子系统已降级
cluster::> system health subsystem show
Subsystem         Health
SAS-connect       ok
Environment       ok
Memory            ok
Service-Processor ok
Switch-Health     degraded
CIFS-NDO          ok
Motherboard       ok
IO                ok
MetroCluster      ok
MetroCluster_Node ok
FHM-Switch        ok
FHM-Bridge        ok
SAS-connect_Cluster ok
13 entries were displayed.
  1. 将记录以下运行状况警报
cluster::> system health alert show
Node: node01
Resource: node01
Severity: Major
Indication Time: Mon Oct 07 13:19:08 2019
Suppress: false
Acknowledge: false
Probable Cause: One or more nodes are not connected to both cluster switches.
Possible Effect: If one cluster switch fails, "node01" might lose access to the cluster.
Corrective Actions: Ensure the switch "switch02" is connected to the node "node01".
Node: node01
Resource: node02
Severity: Major
Suppress: false
Acknowledge: false
Possible Effect: If one cluster switch fails, "node02" might lose access to the cluster.
Corrective Actions: Ensure the switch "switch01" is connected to the node "node02".
2 entries were displayed.
4. 您还可以看到以下运行状况警报
               Node: cluster-01
           Resource: Ethernet1/1
          Severity: Minor
    Indication Time: Wed Aug 25 05:23:27 2021
           Suppress: false
        Acknowledge: false
     Probable Cause: MTU value "1500" on port "e0e" of node
                    "cluster-01" is improperly set. It
                     should be 9000.
    Possible Effect: Received Ethernet packets that are larger than the
                     configured MTU are dropped, causing data transfer
                     issues.
Corrective Actions: modify the MTU using the command "network port
                     broadcast-domain modify -ipspace Cluster
                     -broadcast-domain Cluster -mtu <MTU>". To find out the
                     broadcast domain name of the port, execute the command
                    "network port broadcast-domain show".
5. AutoSupport 报告:
 HMSCSA:HA Group Notification from cluster1-03 (Health Monitor process cshm: ClusterSwitchConfig_Alert[cluster1-03]) ERROR
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
