跳转到主内容
Replication Director :如果源卷或备份选择是 CIFS 路径且归 vFiler 所有、则浏览和磁带备份操作将无法成功
62
Visibility:
Votes:
0
Category:
data-ontap-8
Specialty:
cifs
Last Updated:
适用于
  • Data ONTAP 8.1 ( 7- 模式)
  • 适用于 Symantec NetBackup 的 NetApp 插件
问题
如果源卷 / qtree 归 Data ONTAP 8.1 ( 7- 模式)中的 vFiler 所有、则浏览 / 索引 / 磁带备份操作将不会成功。此故障仅适用于备份选择中的通用 Internet 文件系统协议 (CIFS) 路径。
以下是观察到的内容:
  • 当用户尝试浏览备份时, NBU 栏的 GUI/Restore 窗口中不会显示内容
  • 磁带备份 / 高级磁盘备份失败
NetBackup在日志中
NetBackupGUI 上不会显示任何错误。以下错误将显示在的 Bpfis 日志中NetBackup
错误 1 :在 Bpfis 日志中:
11:52:27.460 [4336.1300] <16> onlfi_import_update_state_files: ERR -  VFM_CMD_IMPORT_IMAGE failed for fi_raw_device [OST_FIM:VxFIv5:<fstype>cifs</fstype><fspath>//10.238.164.43/lvol8/</fspath><state>DEVICE_IMPORT_PENDING</state><fifs_path>C:\Program Files\Veritas\NetBackup\temp\_vrts_frzn_img___10.238.164.43_lvol8__3324_1</fifs_path><vss_prov_type>0</vss_prov_type><fi_db>bpfis.fim.host1_1339481769.1.0</fi_db><fi_copy_num>1</fi_copy_num><fifstype>cifs</fifstype><fsmntdev>NULL</fsmntdev>] fi_fs_name[C:\Program Files\Veritas\NetBackup\temp\_vrts_frzn_img___10.238.164.43_lvol8__3324_1]
11:52:27.460 [4336.1300] <2> bpfis main: IMPORT_UPDATE_STATE_FILES RETURNED [11]
11:52:27.460 [4336.1300] <16> bpfis main: FTL - import update() failed, status 11
And (&)
11:52:28.084 [4336.1300] <4> keep_alive_and_snap_control: Exiting.
11:52:28.084 [4336.1300] <4> bpfis Exit: INF - EXIT STATUS 156: snapshot error encountered
NetBackup以下错误显示在 GUI 的活动日志中:
错误 2 :在活动日志中:
6/12/2012 11:47:06 AM - begin Backup From Snapshot Mount, Import Snapshot
6/12/2012 11:47:08 AM - Info RUNCMD(pid=4516) started
6/12/2012 11:47:25 AM - Info RUNCMD(pid=4516) exiting with status: 43
6/12/2012 11:47:25 AM - end Backup From Snapshot Mount, Stop On Error; elapsed time: 00:00:00
6/12/2012 11:47:25 AM - begin Backup From Snapshot Mount, Unmount Snapshot Status 43
6/12/2012 11:47:26 AM - end Backup From Snapshot Mount, End Notify Script; elapsed time: 00:00:01 Status 43
6/12/2012 11:47:26 AM - end Parent Job; elapsed time: 00:00:24 unexpected message received(43)
在这两种情况下、 NBUPlugin 日志将显示以下错误消息:
2012/06/12 11:51:28: INFORMATION : 10.238.164.46: Attempting to export image. Format CIFS
2012/06/12 11:51:28: INFORMATION : 10.238.164.46: CIFS Export successful. Export path is /vol/lvol8/.snapshot/vfiler1_lvol82012_06_12_11_46_25 and share name is NBU_Share_lvol8_vfiler1_lvol82012_06_12_11_46_25
2012/06/12 11:51:28: INFORMATION : 10.238.164.46: CIFS share permission set successful. share name is NBU_Share_lvol8_vfiler1_lvol82012_06_12_11_46_25
2012/06/12 11:51:28: ERROR     : 10.238.164.46: Failed to set permissions. Removing the export
2012/06/12 11:51:28: ERROR     : 10.238.164.46: Can't export. Reason: Invalid inputs to export the image
New to NetApp?
