AutoSupport 不工作— ASUP 队列命中事件队列阈值的最大大小
适用于
- AutoSupport
- HTTP ( S )
- SMTP
- ONTAP 9.3
问题
- 自动支持不会发送到 NetApp
- 运行
Autosupport history show
时,我们会看到以下错误
示例
Warning: Unable to list entries on node node-02. Timeout: Operation
"autosupport_history_iterator::next()" took longer than 25 seconds to
complete [from mgwd on node "node-01" (VSID: -1) to mgwd at
x.x.x.x.]
Error: show failed: Timeout: Operation "autosupport_history_iterator::next()"
took longer than 25 seconds to complete [from mgwd on node "node-01"
(VSID: -1) to mgwd at x.x.x.x.]
