在ONTAP 9.6 - 9.7中、AFF/FAS重新启动后、AutoSupport失败
适用场景
- ONTAP 9.6到ONTAP 9.7P8
- 重新启动后
- 正常重新启动
- 硬件更换
问题描述
- 重新启动后、无法发送ONTAP AutoSupport
cluster1::> autosupport history show
Seq Attempt Percent Last
Node Num Destination Status Count Complete Update
cluster1-01 2
smtp ignore 1 - 9/28/2020 09:18:05
http transmission-failed 15 - 9/28/2020 11:14:19
noteto ignore 1 - 9/28/2020 09:18:05
1
smtp ignore 1 - 9/28/2020 09:22:15
http transmission-failed 15 - 9/28/2020 10:18:17
noteto ignore 1 - 9/28/2020 09:22:15
