通过路由时, AutoSupport 无法在 ONTAP 中发送 集群间 LIF
适用于
ONTAP 9
问题
AutoSupport 消息无法传输。 运行system node AutoSupport check show-details 命令 将生成如下结果:
cluster1::> system autosupport check show-details
Component: http-post-destination
Status: failed
Detail: HTTP/S POST connectivity check failed for destination:
https://support.netapp.com/asupprod/post/1.0/postAsup.
LibCurl Error (7): Couldn't connect to server.
Status: failed
http://support.netapp.com/asupprod/post/1.0/postAsup.
Server responded with Error: 503.
