跳转到主内容
重新定位集群系统后,聚合无法同化
27
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
适用于
  • ONTAP 9
问题
  • 将集群重新定位到另一个集群后,聚合已拆分 位置
  • 重新定位前:
 Aggregate aggr2 (online, raid_dp, fast zeroed, hybrid) (block checksums) Plex /aggr2/plex0 (online, normal, active, pool0)
  • 重新定位后:
 Aggregate aggr2 (failed, raid_dp, partial, hybrid_enabled) (block checksums) Plex /aggr2_data/plex0 (offline, failed, inactive)
 Aggregate aggr2(1) (partial, raid_dp, partial, hybrid_enabled) (block checksums) Plex /aggr2_data(1)/plex0 (offline, failed assimilation, active)
New to NetApp?
