ASUP 传输失败—从代理收到 HTTP 代码 404 连接后
适用场景
- ONTAP 9
- AutoSupport ( ASUP )交付
问题描述
- ONTAP 升级后 ASUP 传输失败
- AutoSupport 配置使用代理
::> autosupport history show -instance
Node: cluster01-n01
AutoSupport Sequence Number: 1268
Destination for This AutoSupport: http
Trigger Event: callhome.management.log
Time of Last Update: 11/16/2020 02:37:01
Status of Delivery: transmission-failed
Delivery Attempts: 15
AutoSupport Subject: MANAGEMENT_LOG
Delivery URI: proxy.domail.com:8080(support.netapp.com/put/AsupPut)
Last Error: Received HTTP code 404 from proxy after CONNECT
Time of Generation: 11/16/2020 00:28:09
- 与代理的连接可以正常工作,但
error 404 not found在尝试访问 support.netapp.com:443 时会从服务器收到连接
Fri Dec 11 2020 17:20:59 +01:00 [kern_notifyd:info:73500] (category: 73500:3889:deliver) (emittime: 12/11/2020 17:20:58) (message: Connected to proxy.domain.com (x.x.x.x) port 8080 (#0))Fri Dec 11 2020 17:20:59 +01:00 [kern_notifyd:info:73500] (category: 73500:3889:deliver) (emittime: 12/11/2020 17:20:58) (message: CONNECT support.netapp.com:443 HTTP/1.1Fri Dec 11 2020 17:20:59 +01:00 [kern_notifyd:info:73500] Host: support.netapp.com:443Fri Dec 11 2020 17:20:59 +01:00 [kern_notifyd:info:73500] User-Agent: filer/NetApp/9.7P6Fri Dec 11 2020 17:20:59 +01:00 [kern_notifyd:info:73500] Proxy-Connection: Keep-Alive)Fri Dec 11 2020 17:20:59 +01:00 [kern_notifyd:info:73500] (category: 73500:3889:deliver) (emittime: 12/11/2020 17:20:58) (message: HTTP/1.1 404 Not Found)Fri Dec 11 2020 17:20:59 +01:00 [kern_notifyd:info:73500] (category: 73500:3889:deliver) (emittime: 12/11/2020 17:20:58) (message: Server: proxy.domain.com)- SMTP 连接失败,并拒绝 554 5.7.1 中继访问
Fri Dec 11 2020 17:20:59 +01:00 [kern_notifyd:info:73500] (category: 73500:3889:deliver) (emittime: 12/11/2020 17:20:56) (message: 554 5.7.1 <mail@domain.com>: Relay access denied)Fri Dec 11 2020 17:20:59 +01:00 [kern_notifyd:info:73500] (category: 73500:3889:deliver) (emittime: 12/11/2020 17:20:56) (message: RCPT failed: 554)
