跳转到主内容
NVE转换出现ANDU重新设置密钥进度检查错误
5
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9.3 及更高版本
  • NetApp 卷加密 (NetApp Volume Encryption, NVE)
  • 自动无中断升级 (ANDU)
问题描述
  • 正在执行卷加密转换或重新设置密钥、并且可能处于暂停状态
  • andu 已启动
  • ANDU 验证未完成,并引用了重新设置密钥进度检查错误,即使 -ignore-validation-warning true 使用了该标志也是如此
::*> cluster image update -version <version> -ignore-validation-warning true
Starting validation for this update...
It can take several minutes to complete validation...
Pre-update Check      Status     Error-Action
Volume Encryption     Error      Error: There are active volume encryption
Rekey Progress Check             rekeys or conversions in the cluster.
                                 Action: Use the "volume encryption rekey
                                 show" and "volume encryption conversion
                                 show" commands to display the volumes
                                 undergoing volume encryption rekey and
                                 conversion respectively. Ensure that there
                                 are no active volume encryption rekeys or
                                 conversions before attempting NDU.
Overall Status        Error
# entries were displayed.
Validation has reported problems. Please address errors and retry update.
Error: command failed: Validation checks failed with errors.
