NVE 转换出现 ANDU "Rekey progress Check" 错误
适用场景
- ONTAP 9.3 及更高版本
- NetApp 卷加密 (NetApp Volume Encryption, NVE)
- 自动无中断升级 (ANDU)
问题描述
- 卷加密转换正在进行中,可能处于暂停状态
- andu 已启动
- ANDU 验证未完成,并引用了重新设置密钥进度检查错误,即使
-ignore-validation-warning true
使用了该标志也是如此
::*> cluster image update -version <version> -ignore-validation-warning true
Starting validation for this update...
It can take several minutes to complete validation...
Pre-update Check Status Error-Action
Volume Encryption Error Error: There are active volume encryption
Rekey Progress Check rekeys or conversions in the cluster.
Action: Use the "volume encryption rekey
show" and "volume encryption conversion
show" commands to display the volumes
undergoing volume encryption rekey and
conversion respectively. Ensure that there
are no active volume encryption rekeys or
conversions before attempting NDU.
Overall Status Error
# entries were displayed.
Validation has reported problems. Please address errors and retry update.
Error: command failed: Validation checks failed with errors.
