由于与应用程序关联, " 卷删除 " 失败
- 9
- Visibility:
- Public
- Votes:
- 2
- Category:
- ontap-9
- Specialty:
- core<a>ONTAP 9.8</a><a>20088888963</a>
- Last Updated:
适用场景
ONTAP 9.8
问题描述
尝试使用命令删除卷
volume delete
会导致以下错误:cluster1::*> volume delete -vserver vserver1 -volume volume1
Error: command failed: Volume "volume1" in Vserver "vserver" is part of application "application". You must remove the volume from application "application" using
"application volume remove" (privilege: advanced) command before you can delete this volume.
