跳转到主内容
SSL/TLS发生原因secd.ldap.noServers的证书已过期
130
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
适用场景
  • ONTAP
  • 第三方LDAP服务器
  • SSL/TLS
问题描述
  • 在现有LDAP配置上启用SSL/TLS后 、由于与LDAP服务器的连接失败、存储访问可能会受到影响
  • EMS 日志:
secd.ldap.noServers: None of the LDAP servers configured for Vserver (VS1) are currently accessible via the network for LDAP service type (Service: LDAP (Active Directory), Operation: SiteDiscovery).
secd.ldap.noServers: None of the LDAP servers configured for Vserver (VS1) are currently accessible via the network for LDAP service type (Service: LDAP (Active Directory), Operation: MapNetbiosDomainToADDomain).
  • Secd日志:
 error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
 RESULT_ERROR_LDAPSERVER_SERVER_DOWN:7642
 LDAP TLS Alert generated is 'fatal:decrypt error'
 error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01
 RESULT_ERROR_LDAPSERVER_CONNECT_ERROR:7652
secd: secd.unexpectedFailure:debug]: vserver (VSERVER) Unexpected failure.
Error: Get DC Info procedure failed CIFS Domain Query via LSAR_DS_ROLE_GET_DOMAIN_INFO - Client Ip = X.X.X.X
User = DOMAIN\USER   ...
[   236] Successfully connected to ip X.X.X.X, port 389 using TCP
[   377] Unable to start TLS: Connect error
[   377]   Additional info: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed (certificate has expired)
  • Secd日志条目将包含预期 证书的主题
00000013.0022c89e 01eab99b Mon Apr 06 2020 14:31:44 +01:00 [kern_secd:info:14641] | [000.499.972]  info :  Required certificate with <CANAME> is not installed { in VerifyCertificateRevocationViaOSCP() at src/connection_manager/secd_connection.cpp:1667 }
  • 到期日期在CLI命令中指示到期日期:  ::> security certificate show
  • 数据包跟踪可以显示完整的证书链由客户端提供
LDAP服务器示例提供了一个由两个证书组成的证书链
  • 一个是主机本身的证书(颁发者CA颁发的ldapserverhostname),
  • 其他, 中间证书(根CA颁发的颁发者CA)
Transport Layer Security
    TLSv1.2 Record Layer: Handshake Protocol: Multiple Handshake Messages
        Content Type: Handshake (22)
        Version: TLS 1.2 (0x0303)
        Length: 2911
        Handshake Protocol: Server Hello
        Handshake Protocol: Certificate
            Handshake Type: Certificate (11)
            Length: 2587
            Certificates Length: 2584
            Certificates (2584 bytes)
                Certificate Length: 1208
                Certificate: 308204b43082039ca0030201020213160000802cf3c5747b… (id-at-commonName=LDAPserverhostname)
                    signedCertificate
                        version: v3 (2)
                        serialNumber: 0x160000802cf3c5747b5475eb2100000000802c
                        signature (sha256WithRSAEncryption)
                       issuer: rdnSequence (0)
                            rdnSequence: 3 items (id-at-commonName=Issuer CA )
                        validity
                        subject: rdnSequence (0)
                        subjectPublicKeyInfo
                        extensions: 9 items
                    algorithmIdentifier (sha256WithRSAEncryption)
                    Padding: 0
                    encrypted: d403151937a2904d0405e5fe7be043a51969650e43cc27e0…
                Certificate Length: 1370
               Certificate: 308205563082033ea00302010211114500000002578509d7… (id-at-commonName=Issuer CA )
                    signedCertificate
                        version: v3 (2)
                        serialNumber: 0x4500000002578509d77c523cae000000000002
                            rdnSequence: 3 items (id-at-commonName=Root CA)
  • 在此示例中、  Root CA 必须安装的根证书
New to NetApp?
