NDB 备份间歇性失败,并显示错误 "Volume "xxxx" does not exist in Vserver "xxxx" 。原因:条目不存在
适用于
NetApp Data Broker ( NDB ) 1.0/1.0.1
问题
- 在 NDB 备份期间,如果 API 因某些原因而出现故障,则在重试 API 时,指定的 Vserver 名称将不正确。
- 这将导致错误 "
Volume "xxxx" does not exist in Vserver "xxxx". Reason: entry doesn't exist.
例如Volume_A
,卷 " " 位于 "SVM_A
" 中,但在重试 API 时,错误地将其指定为 "SVM_B
YYYY-MM-DD HH:MM:SS.XXX +09:00 [ERR] API exception
YYYY-MM-DD HH:MM:SS.XXX +09:00 [ERR] Failed to run a command New-NcSnapshotMulti
YYYY-MM-DD HH:MM:SS.XXX +09:00 [DBG] ex.InnerException.InnerException.Message : An error occurred while sending the request. Unable to read data from the transport connection: Broken pipe.
YYYY-MM-DD HH:MM:SS.XXX +09:00 [DBG] ex.InnerException.Message : Volume "Volume_A" does not exist in Vserver "SVM_B". Reason: entry doesn't exist.
YYYY-MM-DD HH:MM:SS.XXX +09:00 [DBG] No retry condition match found or max retry reached. Throwing error Volume "Volume_A" does not exist in Vserver "SVM_B". Reason: entry doesn't exist.
