AutoSupport 消息: Element 软件 12.0 及更高版本上的 " 系统内存非常低 "
适用场景
- NetApp Element 软件
- Element 12.0 及更高版本
- Element 12.2 及更高版本
- Element 12.3 及更高版本
问题描述
memoryUsageThreshold
错误代码显示一次或多次:
- 错误状态及详细信息:
System memory is very low. Adding additional nodes or manually purging deleted volumes may help reduce memory usage.
- 警告状态及详细信息:
System memory is low. Adding additional nodes or manually purging deleted volumes may help reduce memory usage.
- 如果这种情况持续存在、还可能导致出现其他警报、例如:
nodeOffline The SolidFire Application cannot communicate with Storage node having node ID <X>.
