跳转到主内容
检测到NVRAM设备问题、元数据驱动器将被删除
34
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
适用场景
  • NetApp Element软件
  • NetApp SolidFire SF系列节点
  • NetApp H系列
问题描述
  • 元数据驱动器变为可用状态或节点意外重新启动
  • 在NetApp SolidFire Active IQ上、将显示以下一个或多个警报:
    • NVRAM device problems detected, metadata drive will be removed. Contact NetApp Support. error={No device found}
    • NVRAM device problems detected, metadata drive will be removed. Contact NetApp Support. error={NVRAM device partition doesn't exist}
    • NodeOffline - The SolidFire Application cannot communicate with node ID <#>
    • NVRAM device error={No device found}
    • NVRAM device problems detected, metadata drive will be removed. Contact NetApp Support. warning={1 activeFirmwareVersion: incorrect version 0.0} critical={Device: 1 Key: armStatusSaveNArmed}
    • NVRAM device problems detected, metadata drive will be removed. Contact NetApp Support. warning={excessiveCapacitorVoltage (XXXx)} error={derivedCapacitanceOfThePack: X.XXX F, derivedEsrOfCapacitorPack: XX.XXX Ohm}
New to NetApp?
