Element Software中的"Drive has failed SMART health check"警报
适用场景
- NetApp Element 软件
- NetApp SolidFire SF 系列
- NetApp H-Series
问题描述
NetApp SolidFire Active IQ 中的错误:
- Error Code
driveHealthFault
- 详细信息:
Drive with serial: <xxxxxxxxxx> in slot: <y> has failed SMART overall health check
- 示例:
Drive with serial: S3SZABCD01234 in slot: 3 has failed SMART overall health check
- 示例:
- Error Code
driveHealthFault
- 详细信息:
Drive with serial: <xxxxxxxxxx> in slot: <y>, Drive should be replaced. SMART data indicates Non-volatile capacitance is failing, raw critical bytes 0-11: 0x10 0x2a 0x01 0x64 0x0a 0x00 0x00 0x00 0x00 0x00 0x00 0x00
- 示例:
Drive with serial: S3T2NX0M305154 in slot: 7, Drive should be replaced. SMART data indicates Non-volatile capacitance is failing, raw critical bytes 0-11: 0x10 0x2a 0x01 0x64 0x0a 0x00 0x00 0x00 0x00 0x00 0x00 0x00
- 示例:
- Error Code
driveHealthFault
- 详细信息:
Drive with serial: <xxxxxxxxxx> in slot: <y>, Drive should be replaced. SMART data indicates health failed, raw critical bytes 0-11: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
- 示例:
Drive with serial: S2TVNB0KA04565 in slot: 1, Drive should be replaced. SMART data indicates health failed, raw critical bytes 0-11: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
- 示例:
