跳转到主内容
Element Software中的"Drive has failed SMART health check"警报
31
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
适用场景
  • NetApp Element软件
  • NetApp SolidFire SF系列
  • NetApp H系列
问题描述
NetApp SolidFire Active IQ中的错误:
  • 错误代码:driveHealthFault
  • 详细信息: Drive with serial: <xxxxxxxxxx> in slot: <y> has failed SMART overall health check
    • 示例: Drive with serial: S3SZABCD01234 in slot: 3 has failed SMART overall health check
  • 详细信息: Drive with serial: <xxxxxxxxxx> in slot: <y>, Drive should be replaced. SMART data indicates Non-volatile capacitance is failing, raw critical bytes 0-11: 0x10 0x2a 0x01 0x64 0x0a 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    • 示例: Drive with serial: S3T2NX0M305154 in slot: 7, Drive should be replaced. SMART data indicates Non-volatile capacitance is failing, raw critical bytes 0-11: 0x10 0x2a 0x01 0x64 0x0a 0x00 0x00 0x00 0x00 0x00 0x00 0x00
  • 详细信息: Drive with serial: <xxxxxxxxxx> in slot: <y>, Drive should be replaced. SMART data indicates health failed, raw critical bytes 0-11: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    • 示例Drive with serial: S2TVNB0KA04565 in slot: 1, Drive should be replaced. SMART data indicates health failed, raw critical bytes 0-11: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
  • 详细信息: Drive with serial: <xxxxxxxxxx> in slot: <y>, Drive should be replaced. SMART data indicates it is read only, raw critical bytes 0-11: 0x08 0x31 0x01 0x5e 0x0a 0x00 0x00 0x00 0x00 0x00 0x00 0x00"
    • 示例: Drive with serial: S438NA0N609921 in slot: 0, Drive should be replaced. SMART data indicates it is read only, raw critical bytes 0-11: 0x08 0x31 0x01 0x5e 0x0a 0x00 0x00 0x00 0x00 0x00 0x00 0x00"
  • 错误代码:driveFailed
  • 详细信息: 1 drive(s) with state: "SmartHealthFailed" driveID: xx
  • 详细信息: 1 drive(s) with state: "NvmeReadOnly" driveID: xx.
New to NetApp?
