跳转到主内容
执行不同管理任务时出现 E 系列 SANtricity Web Server 422 错误
43
Visibility:
Votes:
0
Category:
e-series-santricity-web-services-proxy
Specialty:
esg
Last Updated:
适用场景
  • NetApp E 系列 E2800 , E5700 以及相关 EF 系列平台
  • NetApp StorageGRID 设备: SG5700 , SG6060 和 SGF6024
问题描述
在以下任一其他错误之间、SANtricity 可能会报告以下错误消息:
Data could not be loaded from the storage array. One possible cause is the object on which you were performing the operation no longer exists. Other possible causes include network issues, inability to communicate with the controller, or loss of power to the storage array. Check these causes and then retry the operation.
在不同的管理任务期间、可能会观察到以下错误
  • 在驱动器固件升级期间 - Error accessing the temporary drive firmware directory. There may be a file permission error or the device is full. (Web Server 422)
驱动器固件升级
  • 收集支持数据 - Unable to write to the specified file support-data.7z. Please make sure the specified locations is accessible, the disk is not full and if the file name entered is valid. (Web Server 422)
  • API 调用执行期间出错 - Code 422 - No space left on device
  • 证书更新- Failed to reset array management certificates on Controller X because: The specified file "keystore" could not be delete (Web Server 422)
证书更新
New to NetApp?
