跳转到主内容
SnapCreator Framework for MaxDB 备份失败,并中止 watchdog 正在运行的操作
115
Visibility:
Votes:
1
Category:
snap-creator-framework
Specialty:
snapx
Last Updated:
适用于
适用于 MaxDB 4.3.1 或更低版本的 Snap Creator Framework
问题
用于 MaxDB 备份的 Snap Creator Framework 失败,并显示以下错误:
ERROR: [test-box.netapp.com:9091(4.3.0.0)] Operation failed. Reason: The watchdog killed the running operation. Verify that plugins/wrapper/wrapper binary has execute permission set. Increase the WRAPPER_TIMEOUT_IN_MSEC value in agent.properties if operations require more time to complete.
ERROR: [test-box.netapp.com:9091(4.3.0.0)] SCF-00037: Application quiesce for plug-in [maxdb] failed with error [] and exit code [102], Exiting!
########## Application Unquiesce ##########
INFO: Application Unquiesce for plugin: maxdb
ERROR:[test-box.netapp.com:9091 (4.3.0.0)] Another unquiesce operation is already running on this profile/config MaxDB_Test/NTAP1
ERROR: [test-box.netapp.com:9091(4.3.0.0)] SCF-00032: Application unquiesce failed due to application error. To ignore application errors and proceed with backup you can set APP_IGNORE_ERROR=Y.
New to NetApp?
