创建时, SMSQL 验证在连接数据库阶段失败 FCI 中的克隆
- 11
- Visibility:
- Public
- Votes:
- 0
- Category:
- snapmanager-for-microsoft-sql-server
- Specialty:
- snapx
- Last Updated:
适用于
- SnapManager for SQL ( SMSQL ) 7.2.x 及更高版本
- SQL 故障转移集群( FCI )
问题
- 在该过程的连接数据库阶段,验证失败
- SMSQL 作业报告中显示错误:
"[23:02:03.353] [hostname] Attaching database [database_name_Clone]...
[23:02:03.353] [hostname] CREATE DATABASE [database_name_Clone] ON PRIMARY (NAME = 'database_name', FILENAME = 'disk_name') LOG ON (NAME = 'database_name_log', FILENAME = 'disk_name.LDF') FOR ATTACH
[23:02:03.368] [hostname] [SQL SMO Error]: An exception occurred while executing a Transact-SQL statement or batch.
Cannot use file 'disk_name' for clustered server. Only formatted files on which the cluster resource of the server has a dependency can be used. Either the disk resource containing the file is not present in the cluster group or the cluster resource of the Sql Server does not have a dependency on it.
[23:02:03.368] [hostname] DBCC CHECKDB (database_name__Clone') WITH NO_INFOMSGS, PHYSICAL_ONLY
[23:02:03.384] [hostname] [SQL SMO Error]: An exception occurred while executing a Transact-SQL statement or batch.
Could not find database 'database_name__Clone'. The database either does not exist, or was dropped before a statement tried to use it. Verify if the database exists by querying the sys.databases catalog view.
[23:02:03.384] [hostname] WARNING: SQLServer DBCC CHECKDB failed." -
通过 SQL Management Studio 执行验证,而不使用 SMSQL 以下命令同样失败,并显示相同错误
CREATE DATABASE [database_name] ON PRIMARY(NAME = N'database_name', FILENAME = N'database_path.mdf' ) LOG ON(NAME = N'database_name_log', FILENAME = N'N:\SQLLOG\database_path_log.ldf')"
