跳转到主内容
BRTOLS无法备份、并且未显示任何错误/警告
1
Visibility:
Votes:
0
Category:
snapmanager-for-sap<a>用于翻译</a>
Specialty:
snapx
Last Updated:
适用场景
适用于SAP的SnapManager (SMSAP)
问题描述
运行 backint 命令时、不会创建快照。
检查backint 日志文件和SMSAP server.log后、将显示此异常
[ INFO] SMSAP-07822: Using directory /oracle/SID_NAME/sapbackup for writing the .switch files.
Operation failed. Error: java.lang.NullPointerException
2020-09-18 16:30:26,018 [qtp633070006-243] [DEBUG]: Waiting for RemoteObjectFactory to be registered with GUID b173075e3f6ced5b4623bdfac34a0590 ...
2020-09-18 16:30:27,018 [qtp633070006-243] [DEBUG]: Waiting for RemoteObjectFactory to be registered with GUID b173075e3f6ced5b4623bdfac34a0590 ...
2020-09-18 16:30:28,019 [qtp633070006-243] [DEBUG]: Waiting for RemoteObjectFactory to be registered with GUID b173075e3f6ced5b4623bdfac34a0590 ...
2020-09-18 16:30:29,019 [qtp633070006-243] [DEBUG]: Successfully bound to RemoteObjectFactory with GUID b173075e3f6ced5b4623bdfac34a0590
2020-09-18 16:30:36,113 [qtp633070006-243] [DEBUG]: ServerOperationRunner caught Throwable
     at com.netapp.dlm.auth.CredentialManager.assertAuthenticatedForProfile(CredentialManager.java:453)
     at com.netapp.dlm.repository.common.RepositoryManager$ProfileQuery.queryProfileByName(RepositoryManager.java:1302)
New to NetApp?
