跳转到主内容
SnapDrive 无法创建或连接到虚拟磁盘或 无法创建快照
9
Visibility:
Votes:
0
Category:
snapdrive-for-windows
Specialty:
snapx
Last Updated:
适用于
  • SnapDrive 4.1 for Windows
  • SnapDrive 5.0 for Windows
  • SnapDrive 6.0 for Windows
  • SnapDrive 6.2 for Windows
  • SnapManager for Exchange (200+)
问题
根据所使用的 SnapDrive 版本,可能会出现以下症状 / 错误。
SnapDrive for Windows ( SDW ) 6.x
  • SnapDrive 无法创建或连接到出现 RPC 错误的虚拟磁盘,或者无法创建快照。查看 Windows 应用程序事件日志可显示 RPC 故障,如下所示:
Date: 01/08/08 Source: SnapDrive
Time: 23:09:20 Category: Snapshot event
Type: Error Event: 191
User: NA Computer: MYSERVER
Failed to create a consistent snapshot (name) of the virtual disk(s) \\?\\Volume{0625122e-be37-11dc-bc32-001cc4568b90}\\.
Error code: Failed to get Data ONTAP version running on the filer myfiler.
Error Description: RPC Error - The RPC server is unavailable.
  • SDW 无法通过 FAS31XX 系统上的 e0M 界面检索 Data ONTAP 版本。将显示以下错误:
Failed to get Data ONTAP Version - RPC access denied!
  • SnapDrive 无法使 Data ONTAP 在存储系统上运行,并显示以下消息:
图形用户界面上的消息:
Failed to get Data ONTAP version running on the storage system FILERNAME
错误消息:
RPC Error - Access is denied.
虽然未创建任何 Windows 事件日志,但在 \\filername\\c$ 从 Windows 资源管理器连接到时,将显示以下消息:
The account is not authorized to log in from this station
SDW 5.x 及更早版本
  • LUN 在 SnapDrive 中不可见。发生以下 SnapDrive 错误:
Failed to connect to virtual disk. Failure in mounting volume on the disk. Virtual Disk Name = (diskname) Disk Path = /vol/wow2/q_coredblog/Protocol Type = LUNFiler Name = x.x.x.x UNCPath = \\x.x.x.x\\coredblog\\coredblogRequested Mount Point = HAssigned Mount Point = Error code : Failed to get Data ONTAP version running on the Storage System nfs1.Error Description: RPC Error - The RPC server is unavailable.
  • 在 SnapDrive MMC 中不显示驱动器条目。
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
