跳转到主内容
OnCommand Workflow Automation 中的工作流失败、并显示"无效字符"错误
28
Visibility:
Votes:
0
Category:
oncommand-workflow-automation-wfa<a>1103556</a><a>1296302</a>
Specialty:
OM
Last Updated:
状态信息
适用场景
OnCommand Workflow Automation ( WFA ) 5.1.x
问题描述
OnCommand Workflow Automation 中的工作流失败、并显示"无效字符"错误。十六进制字符可能会有所不同、但它失败的行和位置是一致的。
手动测试认证命令或在<install path> \NetApp\WFA\jboss\standalone \log\wfa.log中查看时的示例:
2020-01-23 21:24:21,724 INFO  [com.netapp.wfa.command.execution.instance.impl.ExecutionInstanceDaoImpl] (default task-1) [Create volume]   ### Command 'Create volume' in 'POWER_SHELL' ###
2020-01-23 21:24:27,178 INFO  [com.netapp.wfa.command.execution.instance.impl.ExecutionInstanceDaoImpl] (default task-8) [Create volume]   Get-WfaCredentials -Host 10.216.25.206
2020-01-23 21:24:27,740 INFO  [com.netapp.wfa.command.execution.instance.impl.ExecutionInstanceDaoImpl] (default task-8) [Create volume]   Credentials successfully provided for '10.216.25.206'
2020-01-23 21:24:28,443 ERROR [com.netapp.wfa.command.execution.instance.impl.ExecutionInstanceDaoImpl] (default task-1) [Create volume]   Failed executing command. Exception: '_x0019_', hexadecimal value 0x19, is an invalid character. Line 1, position 723.
New to NetApp?
