工作流执行显示成功,但未应用更改
适用于
- OnCommand Workflow Automation 4.2 ( WFA )
- WFA 中的 OnCommand Unified Manager 数据源
问题
- 显示为已成功执行的某些随机工作流,但实际上不会对集群应用任何更改。
- 图形用户界面中没有错误
- 在服务器日志中,存在许多错误,如以下错误,指示 cm_storage 数据库的状态错误。
2020-10-30 13:14:51,797 ERROR [org.jboss.as.ejb3.invocation] (default task-26) JBAS014134: EJB Invocation failed on component
CommandMappedObjectEvaluatorImpl for method public abstract void com.netapp.wfa.engine.exec.CommandMappedObjectEvaluator.evaluate(com.netapp.wfa.engine.exec.PlanningContext,com.netapp.wfa.engine.workflow.simple.CommandMappedObject,com.netapp.wfa.engine.exec.ReservationSimulationType,boolean): javax.ejb.EJBTransactionRolledbackException: Workflow aborted.
No results were found. The following filters have returned empty results:
RBS - Filter volume by qtree quota
2020-10-29 09:20:06,558 WARNING [org.mariadb.jdbc.internal.mysql.MySQLProtocol] (default task-30) Could not execute query
select * from wfa.global_config limit 0: SELECT command denied to user 'restricted'@'localhost' for table 'global_config'
2020-10-29 02:52:35,165 ERROR [io.undertow.request] (default task-1) Undertow request failed HttpServerExchange{ POST /error/error.jsp}: java.lang.NullPointerException
2020-10-28 20:25:58,917 WARNING [org.mariadb.jdbc.internal.mysql.MySQLProtocol]
(Thread-34014 (HornetQ-client-global-threads-229006327))
Could not execute query : Query was empty
2020-10-29 02:52:30,726 ERROR [io.undertow.request] (default I/O-3) Undertow request failed HttpServerExchange{ GET jquery/}: java.lang.IllegalArgumentException: UT000068: Servlet path match failed
