OnCommand Workflow Automation 工作流无法修改新创建的FlexGroup的效率配置
适用场景
OnCommand Workflow Automation (WFA) 5.1.1
问题描述
在大型集群或繁忙集群上、从WFA创建FlexGroup 失败、并显示一条错误、指出无法修改效率配置。
wfa.log
2022-06-01 12:37:49,634 ERROR [com.netapp.wfa.command.execution.instance.impl.ExecutionInstanceDaoImpl] (Thread-45360 (ActiveMQ-client-global-threads)) [Create volume] Command failed for Workflow 'workflow name' with error : Failed to modify efficiency configuration for volume "volume name" of Vserver "svm name": Compression can only be enabled when efficiency is enabled on the volume.
