跳转到主内容
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
OnCommand Workflow Automation 引发错误"Expanding of FlexGroup can be possible only on clusters running ONTAP 9.2.0 and above"。
Visibility:
Votes:
0
Category:
oncommand-workflow-automation-wfa<a>2009年:125808</a>
Specialty:
om
Last Updated:
适用场景
  • OnCommand Workflow Automation 5.0
  • OnCommand Workflow Automation 5.1
  • ONTAP 9.5
  • ONTAP 9.6
  • ONTAP 9.7
  • ONTAP 9.8
  • ONTAP 9.9
  • ONTAP 9.10
问题描述
  • 将用于管理集群模式Data ONTAP 的WFA软件包添加到OnCommand Workflow Automation 后、FlexGroup ONTAP 端的命令"WFA卷扩展"将完成、但命令引发错误:
09:34:39.718 INFO  [Expanding An Existing FlexGroup Volume] ***** Workflow Execution Started *****
09:34:39.718 INFO  [Search or define] ### Command 'Search or define' - cluster1:: abc101 ###
09:34:39.765 INFO  [FlexGroup Volume expand] ### Command 'FlexGroup Volume expand' in 'POWER_SHELL' ###
09:34:42.954 INFO  [FlexGroup Volume expand] Get-WfaCredentials -Host xxx.xxx.xxx.xxx
09:34:42.970 INFO  [FlexGroup Volume expand] Credentials successfully provided for 'xxx.xxx.xxx.xxx'
09:34:42.985 INFO  [FlexGroup Volume expand] Connect-Controller -Type CLUSTER -Name xxx.xxx.xxx.xxx -Credential System.Management.Automation.PSCredential -Vserver  -SSLversion TLSv1
09:34:43.016 INFO  [FlexGroup Volume expand] Credentials successfully provided for 'xxx.xxx.xxx.xxx'
09:34:43.048 INFO  [FlexGroup Volume expand] Connect-NcController (with credentials) -Name xxx.xxx.xxx.xxx -Timeout 60000 -ErrorAction Stop -SSLVersion TLSv1
09:34:44.329 INFO  [FlexGroup Volume expand] Connected to cluster node
09:34:44.563 INFO  [FlexGroup Volume expand] Expanding a FlexGroup volume: Start-NcVolExpand -ErrorAction Stop -VolumeName vol1 -VserverContext vserver1 -Aggregate abc_ssd_aggr1,xyz_ssd_aggr1
09:34:45.095 ERROR  [FlexGroup Volume expand] Failed to Expand the FlexGroup volume: vol1. Message: Expanding of FlexGroup can be possible only on clusters running ONTAP version 9.2.0 and above.
09:34:45.188 ERROR  [FlexGroup Volume expand] Command failed for Workflow 'Expanding An Existing FlexGroup Volume' with error : Failed to Expand the FlexGroup volume: vol1. Message: Expanding of FlexGroup can be possible only on clusters running ONTAP version 9.2.0 and above.
09:34:45.188 INFO  [FlexGroup Volume expand] ***** Workflow Execution Failed *****
  • 在选择任何分层选项的情况下、通过预设或自定义工作流运行"Volume Create"命令时、此命令将失败并显示分层错误。此适用场景 同时适用于FlexGroup和Flexvol。
17:19:43.403 INFO [Create volume] Connect-Controller -Type CLUSTER -Name xxx.xxx.xxx.xxx -Credential System.Management.Automation.PSCredential -Vserver  -SSLversion TLSv1
17:19:43.450 INFO [Create volume] Credentials successfully provided for 'xxx.xxx.xxx.xxx'
17:19:43.512 INFO [Create volume] Connect-NcController (with credentials) -Name xxx.xxx.xxx.xxx -Timeout 60000 -ErrorAction Stop -SSLVersion TLSv1
17:19:45.528 INFO [Create volume] Connected to cluster node
17:19:46.294 INFO [Create volume] Failed to create new volume: volume_name. Message: Creation of Volume with Tiering Policy is possible only on clusters running ONTAP version 9.3.0 and above.
17:19:46.450 INFO [Create volume] Failed executing command. Exception: Failed to create new volume: volume_name. Message: Creation of Volume with Tiering Policy is possible only on clusters running ONTAP version 9.3.0 and above.
New to NetApp?
Scan to view the article on your device
