跳转到主内容
无法使用端口 80" 地址已在使用 " 启动 OnCommand 应用程序错误: JVM_Bind"
11
Visibility:
Votes:
0
Category:
oncommand-unified-manager
Specialty:
oci
Last Updated:
适用于
此问题仅会影响安装在 Windows 主机上的以下 OnCommand 应用程序
  • OnCommand Insight ( OCI ) 6.X 和 7.X
  • OnCommand Unified Manager ( UM )
  • OnCommand Workflow Automation
问题
  • 查看的 CLI 输出:> netstat -ano| findstr -i 80,我们将看到: system (通常是 PID 4 )正在侦听端口 80 。  这通常是侦听端口 80 的万维网发布服务。
  • 所有部署文件均解析为 .failed
  • 在系统日志中,您可能会在级联故障开始时看到以下错误:
Services which failed to start: service jboss.undertow.listener.default: org.jboss.msc.service.StartException in service jboss.undertow.listener.default: Could not start http listener.
20XX-XX-XX 16:05:17,892 INFO [org.jboss.as.connector.subsystems.datasources] (msc service thread 1-3) JBAS010409: Unbound Datasource [Java:/onaro_pool_acq]
20XX-XX-XX 16:05:17,908 INFO [org.jboss.as.connector.deployers.jdbc] (msc service thread 1-8) JBAS010418: Stopped Driver service with driver-name = h2
20XX-XX-XX 16:05:17,908 INFO [org.jboss.messaging] (msc service thread 1-2) JBAS011605: Unbound messaging object to jndi name java:jboss/DefaultJMSConnectionFactory
20XX-XX-XX 16:05:17,908 INFO [org.jboss.as.connector.subsystems.datasources] (msc service thread 1-4) JBAS010409: Unbound Datasource [Java:/onaro_pool]
20XX-XX-XX 16:05:17,908 INFO [org.wildfly.extension.undertow] (msc service thread 1-7) JBAS017521: Undertow HTTPS listener https suspending
20XX-XX-XX 16:05:17,923 INFO [org.jboss.as.connector.deployment] (msc service thread 1-1) : Unbound JCA ConnectionFactory [java:/JmsXA]
20XX-XX-XX 16:05:17,923 INFO [org.jboss.as.connector.messaging] (ServerService Thread Pool -- 67) JBAS011605:  Unbound messaging object to jndi name java:/queue/SummaryQueue
  • 尝试通过 WebUI 或 Java 客户端启动 OnCommand Insight 时。Java 客户端返回以下应用程序错误:  Unable to launch the application.
  • 在 JBoss 日志中,报告以下错误:
ERROR [org.apache.coyote.http11.Http11Protocol] Error initializing endpoint: java.net.BindException: Address already in use: JVM_Bind /0.0.0.0:80
  • HTTP 404
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
